Enable ability on ERPS rings to block virtual channel recovery to avoid temporary loops .
| ring-name | Alphanumeric string that identifies the ERPS ring. |
| block-vc-recovery | Block on Virtual channel recovery. |
N/A.
Use this command to enable ability on ERPS rings to block on virtual channel recovery to avoid temporary loops. This is done on interconnected nodes for sub-ring configurations.
enable erps ring1 block-vc-recovery
This command was first available in ExtremeXOS 15.13.
This command is available on all platforms that are running ExtremeXOS.
